Where have they gone?
Hello,
What changes since it last worked?
The basic steps are: restart the TV; check if there are any updates on your TV or device; check your internet connectivity; reset your app preferences;
Hi @Nickpat123 Are you running with the latest software? I believe that you need to be using YouView (not sure). The iPlayers should be found under Sony Select.
