I wondered if anyone else is having the same problem as myself.
I have recently bought a Arris 4K Freesat box and connected it to my KD-49X8309C TV.
When both start up for the first 10 minutes the connection between both are quite unstable. The connection banner on the TV keeps popping up for a couple of seconds and the TV will go black for about 1-2 seconds.
I have tried numerous ways of connecting both, reset the box, I am also now on my the third box that they have sent me but still cannot get to the bottom of this problem.
I would appreciate any advice.
Hi @craigdotcom It is several years since I had my X83C, but have you tried setting the HDMI input for your 4K box to Enhanced?
Hi Lightfoot, thanks for the reply, yes I have tried that but still get the same problem 😕
