hi folks,
i got my TV 4 days ago and so far in loving it. I have a synology nas connected to my network, I can pickup my nas in the default media player but it doesn't support all file types. Has anyone come across a media player that supports all file types and works via Nas and also picks up the fan art and movie description. I have tried Archos which works ok but I'm sure there's a better player out there.
Hi there
These days i dont stream conent, however the general concensus of the community here is an app called Kodi.
Hi there, just tried out kodi, great interface but when I play media I notice the audio is out of sync, noticed lip sync out by approx 1/30 second, I played the same file on the basic player and it was perfect. With kodi there is no option to add fan ar to the file.
Hmmm. Have you tried using Serviio from the diskstation manager on your synology?
Synology apps are not available to download from the google play store for Sony android. I installed Archos pro which works with all file types, also install Archos codec pack and you'll be able to play everything. It also downloads the fan art. I think it works excellent with my synology nas. thanks guys
Thanks quinnicus 🙂
