Have just set up my new X83C, and can't get hdmi inputs 2, 3 or 4 to work. Doesn't register any signal from any of them, however the tv will identify that an audio return channel is active on hdmi4.
Anyone else having the same issue? Any solutions?
Try downloading the latest firmware for your sony tv from your local sony website. Maybe that will solve the problem.
I just bought a ps4pro and seems that i have problems also suddenly my tv start to restart when i use it with hdmi link device i have the latest software on tv witch id 6.0.1 also on ps4 pro also the problems seems is only from when i got my ps4pro i had previously an xbox one s and no problem with but seems like sony dont like each other i think they need a software update on tv or ps4pro i dont know but my tv dont have any problem with xbox one s !!!
i reset everything the tv the ps4pro the problem i dobt have it with xbox one s if i disable hdmi link device is working if is enabled keep restarting my tv
