Hello Everybody.
Can someone tell me if the KD-49X8005C Android TV supports some bluetooth headset devices?
Thanks for any feedback.
Marco
Hi @.M4rc0 and welcome to the Community
I believe the only headphones that will work with this model tv aren't bluetooth.
They are TV dedicated RF headphones which have a seperate send/receiver
Have a look at the MDRRF811 or MDRRF895 headphones.
Hope this helps
Hope this helps
Thanks!
