- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-48A9
Finding it difficult to see the Freeview channel guide… colours make the screen confused for me! And i dont know what the colours represent.
is there any way to obtain a guide screen similar to non Android TV?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Juliet4 Which TV Guide are you using? The native Sony guide or the YouView guide? I find that the native Sony guide easier to view. On my Google TV it is simply a case of choosing which App to run and assign it to the TV button.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ising Sony native channel guide but use YouView occasionally.
i have my TV button assigned to live TV.
Do not understand which app to assign to the button or how do it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Juliet4 If you mean you want to access the Freeview when you press on the TV button follow these steps: Press the HOME button, then select [Settings] — [Channels & Inputs] — [TV button shortcut] then choose digital only for the Freeview and you'll be able to access the YouView through the apps on the Home page.
And if you mean that the issue is with navigating the guide itself, it's explained on the manual: https://helpguide.sony.net/tv/haep1/v1/en/02-01_01.html
