I have recently purchased a Sony KD-48A9
The problem is that with the table stand the TV is flush with the table. This makes it impossible to position a soundbar in front of it as it hides part of the screen.
Is it possible to get a higher stand or do you have any solution to this. I am sure I am not the only one with this problem,
thanks
I believe the stand is intentionally designed to be flush and I honestly have no idea if 3rd-party stands are a thing. That said, you can always mount it to the wall (my personal preference).
