Sony Bravia atch up TV apps not working correctly from day 1.
I did full factiry rest as advised by comments on here and it works ok for a while but then starts to play op again.
TV soft wear / firm wear have been updated on auto update
WiFi signal is fantastic catch up apps wrk fine on laptop
but keep failing om th TV.
I am deeply dissaponted.
Double check that you have the latest v6.5016 version since auto-update sometimes doesn't detect recent updates.
If you're already on that, try clearing the cached data (under Device Preferences - Storage - Internal Shared Storage - Cached data) then restart by holding power.
Hope this helps!
- JD
I agree that you definitely shouldn't have to do that and I contacted the Sony support reps to give some feedback on your behalf.
That said, clearing the cached data every 2-3 weeks is good for maintaining a snappy experience, which is why I usually recommend that first (from personal experience and countless Sony support recommendations).
Hope this helps!
- JD
