Once TV switched on manually using button at rear of TV the remote works fine but
cannot switch off from remote.
Remote checked on similar TVs at dealer who sold me the TV and on/off works perfectly
TV unplugged and plugged in again. No change
TV Factory Reset from settings. No Change.
TV less than 2 years old
Has anyone else had this issue?
Any suggestions for resolution.
Thanks for any help
Hi @Ian1234
My apologies for asking the obvious but there is nothing obscuring the remote pickup window on the TV like a soundbar?
I also went through a period when the power button didn't work as expected on my old KD-55XE9305. It was eventually fixed by a routine software update. However I did get to work during this period by holding down the remote power button for a second or two.
Thanks for the reply but no obstruction and holding down the button has no effect!
