I have recently updated software to PKG6.7140 and ever since when I first turn the tv on in the morning via sky Q it switches off and reboots. After that it is fine for the rest of the day. Is there anyone else having this problem? And is there a way to fix this?
Have you tried clearing the cache (Device Preferences - Storage - Internal Shared Storage - Cached data) and restarting the TV (holding the power button)?
Thank you for you’re reply. I tried this solution a couple of days ago after searching through different posts and wasn’t sure if it was the right solution, but so far it looks to have worked. I just forgot to update it here.. thanks again for helping confirm the solution
@Sipainter is this still fixed for you? I tried clearing the cache yesterday, but had exactly the same problem this morning. Like you I have Sky Q, but my TV is a KD-49XD8305
thanks
Yes it’s been about a week and so far this has worked .. I did also remove all hdmi connections (read that in a different post) and restarted the tv.
Yes and since the latest version was installed that the tv began restarting
Hey @Sipainter,
I was referring to @rbates51 earlier since it was their first post in the thread.
Has the issue returned for you??
- JD
Ahh ok sorry I misunderstood. 🤦♂️The fix was successful and hasn’t returned. Thanks again
