KD-43XG8196 / Netflix
How do I get the Screen to go into full screen mode when watching movies via the netflix app ?
@Dougalmorrison wrote:KD-43XG8196 / Netflix
I’m assuming that you mean aspect ratio and not that you have somehow managed to get it to display in a window.
Unfortunately the Netflix App does not support changing the aspect ratio. This is something you will need to take up with Netflix as they provide the App.
The only way to fiddle with the aspect ratio is to run Netflix from a HDMI connected device set to 1080i/p then you can set the Wide mode in the Action menu to whatever you like.
