When I connect a usb stick on my tv its read only and I cant write or delete any files.How can I fix it?
Are there any settings to change, is this read only thing normal or it is a bug?
Hi again
Sony don't respond on these forums.
Just giving you a heads up that its unlikely Sony UK can help.
Again, why not contact support in the country you are in to let them know
the problem you're having and that you are unhappy.
The more people that do this in each region may help speed things up a bit.
