I have had my KD-43XD8088 since January and, up until a couple of days ago, ARC has worked fine with my Marantz NR1607. Now, suddenly, it has stopped working.
I have tried all the trouble shooting steps I could find (Factory reset of the TV and Amp, checking HDMI cables, plugging in connected HDMI items one by one etc.) but nothing works.
For the time being I have got around the problem by using an optical connection to the amp.
My TV and amp both have the latest firmware.
has anyone had a similar problem?
*** UPDATE ***
I managed to find the culprit.
The problem was caused by my Humax Freesat HDR-1100S which was locked up and completely frozen. After I rebooted the Humax, ARC started working again.
Thanks to all who read my post and I hope this might help others troubleshoot problems they might be having with ARC.
*** UPDATE ***
