what are the differences between these two models? both seem silver (?) according to this link
and is it correct that android apps (e.g. plex) do not send 5.1 audio to a receiver via optical?
thanks!
Hi there
I have had a scan through the differences between the two models. Everything (including MotionFlow rate) is the same - except for the stand design and finish.
| Model Code | KD-43XD8077 | KD-43XD8099 |
| Stand Design | Silver U Slate(Parallel) | Dark Silver U Slate(Parallel) |
| Finish (Surface Color) | Silver | Black |
In regards to Android Apps using 5.1 via optical - this is up to individual app developers. See: https://forums.plex.tv/discussion/167836/5-1-on-android-tv
