TV restarts seemingly randomly after X minutes.
I have tried to do a factory reset and this doesn't seem to do anything as the TV just boots normally (both using the menu and the buttons on back of TV)
I have resorted to manually loading a firmware update via USB however the TV restarts before this process and finish copying the file and once the TV reboots it starts the process again from 0%.
Running out of ideas to try here would appreciate any help that isn't just refer back to the above methods
I will add that I noticed that it was running 5.433 when 5.435 came out last year
