I have just received this TV today, just wondering how to make the screen brighter? It is on max brightness but not bright enough for me.
Hi there
Turn OFF the Light Sensor in the picture settings. More than likely it is this setting that will help increase the brightness
Hi there
Thanks very much for your help, a bit more patience on my behalf is needed. All sorted now.
