Hello everybody
I have KD-43X8305C with firmware version PKG2.287.0010EUB and I can't update firmware with this version anymore, I try with USB stick but no update after many auto reboot.
When I try update on line with TV I have "error 2123" (server error) I don't understand cause
all online services work good on my TV (youtube, google play..)
Notice thaht I live in France.
Can Someone help me
Regards
Hi there
I have sent you a private message with some instructions, let me know how you get on.
Thanks for your answer but your solution doesn't work on my TV.
I follow your instruction step by step but no recovery process diplayed just reboot 😞
Regards;
and me can anyone help!!??
i have tried the update over wifi, which caused the problem, and just tried usb with SONY firmware!!
The TV just switches on from cold start and shows that icon. BRILLIANT>>WELL>>DONE>>SONY!!!!
Hi I also have this exact issue. can you send me the solution please?
It would probably save future work to actually publish this solution too.. just a thought. Thanks
