Before I throw it back at Sony on Monday, has anyone had an issue with their 2015 4k Bravia Android TV continously rebooting? It's basically useless at the moment and stuck on one channel, reboots every few minutes without me even touching anything.
Any suggestions?
Phil
Hi there
Interesting problem you have.
Do you have anything connected to the TV? If so, unplug it, even the aerial cable and see what happens
I hadn't thought of unplugging the aerial but I have now have everything unplugged - no HDMI to soundbar, aerial, cat 6. I couldn't disable the wifi since I can't get to the menu but router switched off...no change...
Hi there
Unfortunately its looking like a hardware fault.
I think you may be right - either that or Android has somehow become corrupted. It feels as though a factory reset would be the obvious thing but since I can't do that, it's a phone call to Sony on Monday. It somehow feels a bit strange that there isn't a purely hardware way of doing a factory reset...
Hi there
I seem to also have an issue where my TV. Will just reboot, go through the start up and. Start viewing again. Checked all sleep timers help welcome. Lucky I have 5 year warranty
Hello @Dazrise3
Sony would like to investigate your problem with your TV unexpectedly rebooting. Are you able to provide more information (see below for questions).
Thank you
Unexpected_Reboot :
(Questions)
Q1 – What is your TV Model Number?
Q2 – Since when did you experience the random reboot issue?
Q3 – How often does the random reboot issue occur (i.e. once a day, twice a day, once a week etc.?)
Q4 – Are you able to consistently reproduce this issue?
Q5 – How does your TV receive its broadcast signal?
Q6 – Is a CAM card necessary to reproduce the reboot problem?
Q7 – What other devices are connected to the TV?
Q8 – Does disabling Interactive Applications help avoid the reboot problem? (Instructions: HERE)
Q9 – Does turning OFF “Update Guide in Standby” help avoid the reboot problem?
(HOME > Settings > Channel setup > Digital Setup > Guide set-up > Update Guide in standby > OFF)
Q10 – Any other additional information to add?
(Questions)
Q1 – What is your TV Model Number? KD-498305C
3 or 4 times a week
unsure what this is
Sony Soundbar and DVD Player
NO
NO
Quinnicus adding : Unexpected_Reboot
@Dazrise3 - Thanks. Sony should pick this up. I added a slight note to the end of your post, specifically for Sony. Cheers
