I want to record via the guide system which works brilliantly, however, if I want to use ITV hub it appears I have to install YouView which besides being horrible doesn't allow me to record, either way I loose a function. Is there any way to use ITV Hub without installing youview?
Hi there
No there isnt im afraid. However if you have a smartphone or tablet, you could use screen mirroring and have ITVHub running on one of those devices.
