I am currently unable to access the ITV hub or All 4 on my new 55 AF8. I can use IPlayer and other apps, so my internet connection is OK. ITV hub will not load and All 4 loads and displays content but will not play it, citing a playback error. I was also unable to register the TV online using the registration App and a cheery message from BT was displayed telling me that I was now connected to my home hub.
i can see that others have experienced similar problems, but they all seem slightly different. I have tried all the usual factory resets and so forth.
any guidance and suggestions will be appreciated. Surely Sony aren’t selling a product that is just plain faulty.
thanks
For reasons known only to Sony and my ISP (BT), last night the EPG was fully populated, All4 and ITV hub were up and running, and All is now well.
baffled!
Hi there,
To access the ITV Hub and All 4 apps you will need to enable YouView on your TV. You can see more details about the YouView Overview and Setup here.
Let me know how you get on.
Best wishes,
Sean Mc
Hi Sean
thanks for that.
i have YouView enabled and the EPG remains largely unpopulated and All 4 remains unavailable. I only have low broadband speeds, but they are sufficient for streaming so that shouldn’t be an issue.
regards,
David
Did you perform a full factory reset?
I had issues with All4 and my EPG with the channel logos missing and the guide not fully popualting especially HD channels, do you have these issues?
Nothing but a full factory reset worked for me.
I may well have to do a reset. I was trying to avoid it, as the telly is only a week old but maybe I’ll end up doing just that. I’m using it mostly to display the output from a Humax pvr so its not too much of an issue. It’s just irritating when you’ve paid good money.
baffled!
Did you ever get it sorted I’ve disabled and enabled you view still nothing l, it only brings up iplayer and my5 ?
Hi, it seems to be a software issue, make sure to update your software to the latest version.
