I’ve just received an emal from Sony inciting me to update my TV to Android Oreo. My TV has automatic updates turned off because past updates had bugs which disrupted the TV functionality. I have seen large numbers of posts on here saying the Oreo update is buggy and has disrupted many functions from video playback to sound and ARC. Does the Sony email inviting updating mean that the Oreo update is now fixed and safe to use..... or is it still risky? Thanks
@Kuschelmonschter wrote:- The Linux kernel now uses a Z-RAM (compressed RAM drive) as swap area. That should improve things when there is need for memorySony should consider debloating their system. I removed some useless crap (like Samba, Sony Select, DIAL, BIVL, IRB, interactive) and gained 250M of RAM.
By "removing" do you mean disabling or actually uninstalling a system app? And how?
Not for me, messed my wifi up. Cannnot connect after Oreo 8. Had to perform factory reset, now have lost some action menu options.
@Kuschelmonschter wrote:It really depends on what you need. Here are some things that I always remove:
u0_a114 7514 1250 1711856 17832 SyS_epoll_wait 0 S tv.samba.ssm u0_a66 21470 1250 1717384 30224 SyS_epoll_wait 0 S com.sony.dtv.dialservice u0_a30 20972 1250 1702680 30520 SyS_epoll_wait 0 S com.sony.dtv.irbservice u0_a73 19666 1250 1699716 24956 SyS_epoll_wait 0 S com.sony.dtv.bivlinfo u0_a65 20183 1250 1706884 29460 SyS_epoll_wait 0 S com.sony.dtv.youview u0_a127 19514 1250 1712276 33500 SyS_epoll_wait 0 S com.sony.dtv.sonyselect u0_a101 3333 1250 1731676 34484 SyS_epoll_wait 0 S com.sony.dtv.interactivetvutil system 6482 1250 1696276 13844 SyS_epoll_wait 0 S com.sony.dtv.interactivetvutil.output u0_a100 6497 1250 1705260 18556 SyS_epoll_wait 0 S com.sony.dtv.interactivetvplatform
If you don't need the Video app, you can also remove that plus alle the flaky DLNA (Huey) modules. If you don't need integrated tuners, you can also remove a lot of that stuff.
DIAL is an old thing and has been superseded by mDNS. Never experienced any issue in the way I use the TV.
My XE9005 with Android 7 doesn't let me disable half of those? I can force close but nothing else???
I was thinking that it should be an ADB method.
Thanks for the link.
I ain't going to run the *.bat file, but I might try to uninstall some of the apps that you 're suggesting and I have already force-stopped.
@zer0ner0 wrote:I ain't going to run the *.bat file, but I might try to uninstall some of the apps that you 're suggesting and I have already force-stopped.
We can't unisntall system apps. One needs root for it. The method suggested in reddit, the same I was talking about, disables them, though. Force-closing doesn't achieve much. They may restart automatically even without rebooting.
Also instead of running the .bat file you may copy and paste the lines for the apps you want to disable. What I never understood is how one can enable them again, without a factory reset. But I didn't investigate much.
@Jecht_Sin schrieb:Also instead of running the .bat file you may copy and paste the lines for the apps you want to disable. What I never understood is how one can enable them again, without a factory reset. But I didn't investigate much.
Do a
adb shell pm list packages -f
and you will get for each installed package the APK, e.g.
package:/system/app/SonySelect/SonySelect.apk=com.sony.dtv.sonyselect
To re-install, do
adb shell pm install -r --user 0 /system/app/SonySelect/SonySelect.apk
@Kuschelmonschter I forgot the command was "pm uninstall". I was sure it was "pm disable". But so what does it do exactly? The apps are in /system, which is mounted read only (unless of yet another stupid trick that installs them in /data/apps instead).
Anyway, thanks for the command to reinstall/reenable them!
And also netflix goes banana... It keeps running (fully) in a CPU core, apparently. This is the extract from "top" command (Android 8 has a MUCH better Unix shell, now. Quite complete):
Tasks: 342 total, 1 running, 307 sleeping, 0 stopped, 2 zombie Mem: 1603708k total, 1468428k used, 135280k free, 18044k buffers Swap: 1196348k total, 446384k used, 749964k free, 306820k cached 400%cpu 3%user 48%nice 65%sys 282%idle 2%iow 0%irq 1%sirq 0%host PID USER PR NI VIRT RES SHR S[%CPU] %MEM TIME+ ARGS 5209 u0_a143 20 0 2.0G 65M 20M S 95.3 4.1 126:31.92 com.netflix.ninja 1650 root RT 0 0 0 0 D 8.6 0.0 165:38.29 [MLVdo_thread]
Obviously Netflix isn't running. Sure it must be on background, but "Recent apps" is broken, so.. Actually "Recent apps" doesn't even show it.
And to the void also Netflix goes.. I have an Apple TV 4K anyway!
