x
Martin16v
New
Ir blaster
Just got a Bravia 65 inch tv and the ir blaster cable isn't long enough.
Is there an extenstion cable i can get maybe 5m.
Thankyou
2 REPLIES 2
profile.country.IT.title
Marino.Manolo
Genius
5 M? Maybe you would not use it in the right way, for that length it seems that you want it to be placed in front of the armchair ...
Manolo
Sorry, I don't understand your reply.
Our TV is mounted on the wall above a fireplace. There is no room for a set-top box near to the TV, so it is situated some 4 metres away.
The supplied IR Blaster cable is not long enough.
Therefore my question is straightforward: Do Sony make/provide an IR Blaster with a longer cable?
Thanks!
