hello,
had to get a replacement TV as the screen packed in just over a year old!
just wondering if there was a way to set up sky Q remote to switch the tv on/off without the IR blaster?
as i used it on my old tv and pressed the home button and the tv would come on but i cant find my blaster and didnt get a new one.
hope you can help
thanks
Hi Munky,
As far as I can tell, the IR blaster that comes with the TV allows the TV remote to control your Sky Q box not the other way around.
Cheers,
Tenneen9000
