Can't get iplayer to work on my kd-55a1 TV. Tried factory reset nothing works. Iplayer used to work okay but now it doesn't. Anyone having the same problem.
Hey @Peter44Flynn, which software version is currently installed? Also try to clear the TV's cached data ( Settings - Device Preferences - Storage - Internal Storage - Cached Data ), then give it a go again.
Had the same problem. Solved it by restart TV - switching off and on at the mains. Seems to have worked for now……….
Hey there, after the recent update you can find it in ''Sony Select'' through the home menu, maybe try to search for it there.
Hope it helps.
