x
Internet messages on Tv
profile.country.GB.title
Chunk828
Explorer
I keep getting messages on my Sony Bravia that I’m not connected to the internet, then a few seconds later that I am connected. It seems to have happened since a recent update. I have done a factory reset and it’s not solved the issue.
2 REPLIES 2
LightFoot
Specialist
Hi @Chunk828
What is the full model number of your TV (it will start with KD) and what are the details of the connection? When this happened to me it highlighted a failing Ethernet switch. I believe the latest software tests the integrity of connections to a higher decree.
Chunk828
Explorer
my model is
KD-43XF8577
the problem has started since the recent update, a week or so ago.
