Can anyone tell me why I need to tell my TV that I am in the UK every time I want to access the internet?
The TV settings tell me I am in the UK and the TV is set to find my location via the wireless internet connection.
It is no big deal but it is annoying. Surely I can lock the information into the system somehow?
Any help or info would be appreciated.
Thanks
Usually you only have to set-up your connection once and the TV memorizes the settings.
If it doesn't there might be a technical issue. You might want to contact support.
