Hi, we have just bought two KDL50WF663 to use in the same room. Is there a way to set the remotes separately so that they each only operate one tv and not both? Advice much appreciated. Thanks
Hi there,
Hopefully a community member will be able to help.
Best wishes,
M
Hi SonyNewby,
I don't think there is a workaround for this. The only way that I could think of is to unplug one of the TVs from the mains if you'e not using it.
Cheers,
Almou_10
