As per the thread title. Every time I switch on the tv (KD-49XG8096) the inputs screen is displayed instead of the television. It always points to the HDMI-1 channel even though there's nothing plugged in there. I only have a soundbar attached which is in the HDMI-3 (ARC) Audio input. What gives? It's more of a nuisance than a major problem but annoying all the same. Anyone got any idea how how to solve this issue?
Thanks.
I think it's up to date. Tried last week and it said no updates were available.
Hey pec771, can you post the current software version? Press Help on the remote to get it.
Version 9 make any sense? There used to be more detail but settings seem to have changed since last update. Will have a better look tomorrow.
Hey pec771, you can get it from the Help menu, just press help on the remote it should be on the upper part of the screen.
PKG6.7165.0360EUA
Hey pec771, try to reset the TV to the factory settings, let me know if that help.
OK, will have a bash at that tomorrow. Thanks.
Hey pec771, what happened? Did it resolve the issue?
'fraid not. Out of options here. Very odd.
@ pec771, I say contact Sony, this doesn't seem to be right.
