Hi does anyone know where to get a replacement remote sensor from please . I've tested my remote and it's working fine so it's definitely the ir sensor . I can't find anything on Google . Any help much appreciated thanks jue
Hi Jue,
Welcome to the community.
I'll see if i can find this out for you. Maybe someone else in the community can help in the meantime?
Thanks,
Pascale
Hi Jue,
You can try to look over here: https://bit.ly/2iEzmyS, they sell original Sony spare parts.
However, I guess that only service centres can get their hands on these spare parts. You can try to contact the nearest one from you using this link: http://bit.ly/2HUo9mF.
I'd also recommend doing troubleshooting on the TV like updating the software, unplugging all external devices, and doing a reset if possible to make sure it's not a software issue.
Hope this helps,
