Whether I'm watching Sky TV or a 4k bluray, I get a black bar that pops up on top of my TV screen.
This is the bar that shows HDMI, picture resolution etc.
Is there a way of turning this off?
Does anyone know what causes this?
Hi Blumine, I have recently contacted Sony support about this and they advised that this is being investigated by their engineers; however, as a workaround for now, you can disable the info banner by pressing home- select settings- watching TV and set the info banner to OFF.
I really appreciate you getting back to me.
This is welcome news.
It's really frustrating!
Many thanks
