Hi there!
My name is Zsolt Meszaros. I bought around 2 years before 2 Sony products from Currys PC World,
a Sony Bravia KD65-A1 OLED 4K Android TV and a Sony HT-ST5000 Wireless Sound Bar with Subwoofer.
I told the delivery team, they can took away these product boxes. Now I just realised, that was a huge mistake.
If I need to moving out from my rented room, I can't transport these lovely products in safe without these original boxes and packaging.
I already asked Currys PC World and Team Knowhow, but they not stored any boxes...
Is it possible somehow, for a reasonable cost to ask Sony or the Sony packaging manufacture to remake these original product boxes for me with the original inside packaging if I will pay the cost?
Can they post these to my selected address if my enquiry solved?
If they can't make for these, how can I have these boxes? Have any ideas?
Thanks for the answers and time!
Regards
Zsolt Meszaros
Hi Zsolt,
I will check internally but frankly spoken I doubt that this will be possible.
I'll keep you updated.
Hi Zsolt,
Just received the information that this isn't possible from official side.
So maybe the option that @royabrown2 has posted is best for you.
Hi Peter,
Thanks very much, you checked that for me.
Thanks for the time and the suggestion as well.
Take Care buddy 🙂
Regards
Zsolt
Hello mate
Thanks very much this solution.
I find a bit better in the past time, but I tried to get original boxes if possible.
I see, it isn't so I will give up, and choose the cardboard solution.
This one a bit better, because including all the packaging stuff too :
