How to add persian or farsi language or keyboard to sony LED kd49xf7005
The language list is not available
Hi there,
I'm looking into this for you and will update the thread as soon as I have more information.
Best wishes,
Sean Mc
Hello Behnam,
I don't think you can add more languages to the pre-loaded ones. The keyboard will either follow the same system language, or you can select a different language (Only from the same list).
Vanilla_
schade
Adding a language on Android does not have to be difficult
Hello again Behnam,
I hear you. It doesn't seem that your KD-49XF7005 is an Android TV. I looked up the specifications of this model and it's running Linux: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kd-49xf7005
Regards,
Vanilla_
What should I do?
Does not Sony's customer service help me?
Hi Behnam,
I'll try to pass on your feedback regarding this to Sony.
Regards,
Vanilla_
This is a problem that the device is not compatible with different languages
Thankful
Display language for that model:
BULGARIAN / CATALANO / CZECH / DANISH / GERMAN / GREEK / ENGLISH / SPANISH / ESTONIA / FINLAND / FRENCH / JEWISH / CROATIAN / HUNGARIAN / ITALIAN / Kazakhstan / LITHUANIAN / LATVIAN / DUTCH / NORWEGIAN / POLISH / PORTUGUESE / ROMANIAN / RUSSIAN / SLOVAK / SLOVENIA / SERBIA / SWEDISH / TURKISH / UKRAINIAN / BOSNIAN / MACEDONIAN
Manolo
Yes, I know, but I have to be able to add other languages to the keyboard.
Device language is not important, but it's important in Keyboard
