hi all im in kodi and trying to save some films to favarites but witch button on the remote is it ?? on my other android box there is a button with 3 lines on it that you press to put sub menu up to add to fav;s but cant see any on the remote can any 1 help
kind regards
fether
ok iv sorted it i needed to use a usb keyboard and press c
regards
fether
Thanks for letting us know you've solved it.
Another way of doing it is to install the "keymap editor" add-on in Kodi and then program your remote control. I assigned the "context menu" to the red button of the remote control and it works without a problem.
You can find some tutorial regarding Keymap Editor on Youtube.
