I use my TV with a USB connected disk for scheduled timer recordings. Some recordings are once and some are re-occurring, e g every week: Tuesdays at 2200-2230. I book the recordings in EPG. Recordings work fine but they were set to a specific time and when time changed due to daylight savings - the recording is one hour wrong.
How do I remove a future scheduled timer recording? Especially a re-occurring one?
In EPG I see a red line above a scheduled program but I do not see any option to remove the recording.
My TV is a KD-49X8305C and I use DVB-T (not IP-TV) but TV is allways internet connected over my home wifi and therefore allways updated with latest released firmware.
Thx in adavnce!
/Patrik
Go to EPG(GUIDE) again.
Press LEFT arrow key on Remote Control.
From list Select TIMER LIST. At bottom you see a note "The ACTION MENU button: Delete timers, etc
Press Action Menu button on remote
Select Recording timer list, then Delete .... and just delete what you don't want to be recorded again.
Hi there
I cant see mine at the moment, so not too sure. But many actions are available by pressing the action menu button on the remote control. So go to scheduled recordings and then action menu. Is there an option to delete available?
Thx a lot MiCal1967 - exactely what I was looking for!
/Patrik, just accpeted your your respons
Although this was a 3-year-old post but has helped me today to solve the problem on my tv. Thanks, Micah once again.
