On a KD-55X9005 the Opera app breaks down the streaming speed so low, that the running cycle in the middle of the screen runs all the time, showing a timing/jitter problem.
It is not a client throughput issue, the Berliner Philharmoniker app is OK, the same streaming on Opera browser (https://www.digitalconcerthall.com) is not.
E.g. medici.tv can be received only by browser, they have no app for IPTV and the Opera is just not suitable.
Hi there
Can you please confirm the full model number of the TV - its either:
Although, Sony TVs do not support flashplayer - which many streaming services require when using a browser - hence the use of apps.
KD-55X9005C
Both digitalconcerthall.com and medici.tv could be seen in good quality,
but the ceaselessly revolving circle is very annoying.
