Hi there
There are some good suggestions there, but some of them cannot be changed as its as per design. Just going to quickly run though your list.
Point 1:
This will not change unfortunately, ITV Player and 4OD are only available via YouView. I believe you can 'cast' these however via a tablet/smartphone etc.
Point 2:
You can disable YouView in the TV settings if you do not wish to use YouView. See HERE for instructions
Point 3:
In an ideal world I agree. I do not know the full or real reason for this, but cannot see it changing though.
Point 4:
Agreed - hopefully this will get future development, but who knows.
Point 5:
PIP/PAP have been introduced - but a little limited. However it has already been suggested to Sony to increase its funtionality.
Point 6:
Will not happen - Sony's TVs are not Freesat - Freeview Only.
Point 7:
You can do this, but you must disable YouView. Satellite services and YouView do not function together.
Point 8:
Im not sure on what you are meaning on this. But in recent firmware updates the TV has felt more responsive.
Point 9:
Agreed. However there is now an app to change the Netflix button to another app. See HERE
Point 10:
Correct, see point 1 above.
Point 11:
You can sideload Google Chrome yourself. See HERE
Point 12:
Has been improved in recent times. However I understand with a future release (Marshmallow) this will be fixed.
Point 13:
I believe pressing the discover button on the remote is how you access it.
Since your post, things have improved, but there is still a way to go.
