Anyone know how to shut off the painfully annoying beep every time i try and scroll through my apps?
I have the new x85ju 4k tv and as far as i can see it doesn't have the same options as the previous software to disable "System Sound" in the settings..
Press the (Quick Settings) button on the remote control, then select [Settings] — [System] - sound
