I have just finished setting up my YouView box and went to type in my post code and entered a incorrect digit and cannot see any way to change it.The screen says 0 for space and DEL for delete.I can only see one key with delete on it.It says SUB on the top and DEL on the bottom I have pressed that key but nothing happens anyone have any ideas.Thank's
Hi there
Which YouView box? One from TalkTalk or BT?
TalkTalk
Hi there
This guide tells you to press the 'del' button to delete a wrong character.
https://support.youview.com/articles/Self_Service_FAQ/My-YouView-box-won-t-accept-my-postcode
