Hi
How to add Biss Keys Manually in KDL-43W805C
please guide me
Hi Cyberlife
You cannot do this with embedded TV Satellite system.
I also think that Common Interface modules with support for the BISS CA system, defined by the EBU, are hard to find or do not exist.
The best solution in any case is an external receiver like amiko 8140. They are very cheap and around 30 to 50 euros.
A shop that sells satellite materials in your area will help you better for your choise and explain if another solution exists.
I have read complaints from owners of other TV brandts(LG) about this but ther is no solution.
