x
Ivan1223
Explorer
How remove this note
When i start up tv this note is always on screen.
How remove that?
Is that from kodi or es file explorera, file managera?
http://i68.tinypic.com/290ty5s.png
Sony Android TV - KD-55SD8505
3 REPLIES 3
Anonymous
Not applicable
Hi there
You photo unfortunately doesnt give any context on where this occurs on what screen - but ES File Manager could be the culprit as it has been know to create on-screen popups.  Try removing that app and see what happens.
profile.country.GB.title
barsoy74
Explorer
I had the same issue a couple of weeks ago, uninstalled es-file explorer and problem solved
chrisc383
Member
It is from ES File Explorer, they call it floating icon, can be disabled somewhere in settings. In theory, clicking on it gives you ability to take a screenshot, mark something, etc, but I couldn't figure out how to activate it on the TV set.
