How do I set up my Sony Bravia 2015 TV to mirror from Apple and Android devices?
I am able to down load mirroring apps but none seem compatible with a Bravia 2015 TV
Hello @majaly,
why do you download "mirroring apps"? Do you use an Android Smartphone? If yes, then MiraCast is build in your phone and you should be able to case to your TV easily from the settings menu of the phone.
If your TV doesn't support screen mirroring, you can get a Google Chromecast or a Microsoft Display adapter which allows for wireless screen casting via MiraCast.
. Nic
