Is there any apps on android that i can manually increase video height?
Saamsung have this awesome feature built-in.
@sagor1 wrote:Is there any apps on android that i can manually increase video height?
Hi @sagor1. I am not sure what you mean by video height but if you mean aspect ratio then this can be found using the Action Menu -> Wide mode. Note this option is unlikely to be available for UHD.
I mean when i play video via pendrive i want to stretch the video height for removing the black bar.
I already tried Mx player manually changing the height....no luck.
BTW my tv model 55x800e
@sagor1 wrote:@LightFootanything?
Hi @sagor1. Sorry nothing to add. If Wide mode is not available under the Action Menu then the option to change the aspect ratio is not available. If you go to Digital TV you should see it in action.
