hi
How can i enter audio pid ,video pid, pcr manually in KDL-43W805C
Hi
Do you mean General Satellite for those you say and also the Biss keys?
I think you have not the option to do this. They are auto.
About Biss I suppose you have to call Sony support or your provider(DIGEA?)
Yes, I mean internal television receiver
Sorry if English is not very good
When you perform a manual digital adjustment with DiSEqC Disabled you can adjust:
On Transponder just:
On LNB Configuration:
Try this procedure:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/69211/kw/satellite%20adjustement
and experiment by yourself.
If no signal detected, try go back to Digital and then back again to Satellite.
