Any ideas why tv turns itself off after approx 1 minute.
Tv won't power up again for hours then finally works for 1 minute again.
This has been going on for a few weeks!
Tv is kd65xf8796
Hi @Biillleeee
If you have tried disconnecting everything apart from the power cord, I would try resetting the TV.
Thanks
Unfortunately TV won't stay on long enough to reset anything
@Biillleeee wrote:Unfortunately TV won't stay on long enough to reset anything
Hi @Biillleeee That scenario is in the instructions - “Is your tv responsive? - NO”.
