Hi
I have a 55x8500c Sony Android tv (Asia model),
Previously I had a problem, My tv won't update to any firmware, It was rebooting at 53% exactly everytime when it tries to copy the update file from usb.
I was searching for a solution, So I enabled developer options, and I tried "adb reboot recovery" It didnt enter any recovery, simply it restarted.
Then I tried "adb reboot bootloader" , Now it is stuck, It shows sony logo for a few seconds and the display becomes blank. White led is also not glowing.
It is bricked, Any solution will be very helpful.
Thanks
Hi guys!
I have success with my SONY BRAVIA KDL-75W855C ( 06/2015 ) ( RESOLVED ).
The tv has problem with software then i downloaded latest Firmware from SONY (noughat)
so i got bricket my TV ( stuck on boot logo after update )
no one of button was working so i cant to do Factory reset or turn off the TV.
Tested 15 ways… no green light comming up.
SOLUTION:
I get off the back cover to access motherboardet ( there USB/ HDMI and AUX are )
Then i plugged out the silver group of cables which come from the POWER SUPLY boarded,
and the speakers, and the buttons panel cables.
I hope that will fix yours problem.
by One boy from Bulgaria ( Hristo Kushev )
Just to understand @Mursata : why did you open your tv to make the standard procedure provided by Sony?
Hi. I have Kdl-43w800c. It suddenly gone and now just Sony logo on the screen. It doesnt respond any button combination. Also i tried to take off back cover and unplug/plug motherboards cable it doesnt affect anything. Still same
Also there is no any led light white or green on it.
Could you please help me with this issue.
Thanks
