Hi!
I have SONY KD75XD8505BAEP 75" 4K UHD SMART TV
When I bought this TV the description says it has HDR
I tried to use hdr on my ps5. Cant get in on 😞
I have good new HDMI cable.
Can you tell me where is the problem?
Thank you
It depends what you want to pass to it, it doesn't support 4k@120 fps HDR input regardless of the cable
So this tv doesnt support hdr?
I didn't write that, and you can easily check on YouTube if it support hdr
Okey, thak you!
HDR works now, I found the problem.
Thank you rooobb !
If you can, share the problem/solution here so that it can help other with the same set up
