So google play store updated in the past day or so and now it's no longer showing up on the app list. If I go into settings -> apps and try to open it from there it says it's not compatible with my device. This means I can't update any of the apps now. Using KD-55XE9005 with v6.5629 firmware
Hi there,
Have you tried a factory reset?
Best wishes,
M
no, I removed play store updates and its working again, that is until it updates automatically again....
