4 weeks ago the Google Cast icon stopped showing on my mobile apps, which meant I couldn't cast to the TV.
We realised this was due to an issue with the TV, which only a factory reset would fix.
The factory reset fixed the issue for about 1 week, but now it's back.
What's causing the issue, and how do we fix it?
Hello @ChrisJamesButSonyForum,
normally you can delete the cache of the Google Cast app on its won in your app settings.
- Nic
Thanks for trying @IamNic, but that didn't help either.
I've been on the Chromecast built-in TV app and cleared cache, cleared data, disabled & enabled, and it's still not worked.
I've also uninstalled updates on the Chomecast built-in TV app and reset the TV, but that didn't work either.
Then I tried force stopping the Chromecast built-in TV app, and it's still broken.
Finally I did another factory reset but that didn't even fix the problem this time.
What is left to try?
