Hi, can someone please confirm the file size for FW v6.1004 dated 15.03.17.
On the download page it states it should be :- 1,588,929,932 bytes
But I've downloaded it twice & each time it unzips to :- 1,588,660,386 bytes ?
Is the web page wrong or the file ?
Thanks & Regards
tv is KD-49XD8099
Hi there
I have just downloaded the file and as you can see, the file size posted by Sony is correct. Look at the file size before you unzip it.
Thanks for the confirmation, I'd only checked after unzipped, mistake on my part. I'll try the update soon.
Must say what a good picture this set has got.
Thanks & Regards
