i have the sony KD-49X8305C waiting in customs.the ask for the frequency range of 5 GHz wireless. (for example : 5150MHZ-5300MHZ) how can i get this info?
It most probably depends on from which region in the world the TV comes from... But then again it is hard to get to that information without trying it out. I don't think that Sony's technical support knows this as they usually know nothing at all...
the Tv comes from the UK
http://www.sony.co.uk/support/en/product/KD-49X8305C
i didn't found any info about it in the support web
the problem is that customs insist that i will give them the frequency range.
how can i find it? there is no way to know this?
5GHz spectrum in the UK is 5150-5850MHz. But I don't know what the Sony HW and FW allow. Should be the same for all European models. I know that with some older FW, I could only reliably connect via U-NII-1 frequencies. I once tested how far I can go with the most recent FW. But I don't remember. I think all the way up to 5850MHz.
Hi there @shaytola
Going to http://www.wi-fi.org/ and searching for your model TV gives the certifications required. Please see the attached PDF document.
Other than that - I find this a rather unusual request by customs - Sony TVs comply by the required industry specifications.
